Batch Render for Rhino
  • #61
    Re: Batch Render for Rhino
    I'm having a similar issue/problem that was also brought up before. Right now when I try to render a batch sequence (4 camera views) all the views render but fail to save (saving as a *.png)
    I checked the log file and it says everything is successful.
    • #62
      Seems simple, but in the options tab, make sure that you have the batch render button checked.
      • #63
        I have figured out the error that I was getting earlier. The problem was that I had the Windows Vista User Account Control enabled. As soon as I turned it off, restarted my computer and tried to use the batch render, it worked! After a few months of frustration it suddenly hit me today!
        Thanks!
        • #64
          Hi Everybody,
          I'm just getting started with Vray, but I wanted to complement you on this batch render tool. Its one of those things that you knew you where missing on previous rendering software, but couldn't quite put your finger on what it was. I think this kind of tool is as important as the rendering engine itself, because it increases productivity.
          I have not yet had any issues with it in Windows7 64bit, but after reading through this thread, I appreciate all the patience and help the moderators have provided.
          • #65
            Great tool!
            In general.
            But there's one thing that keeps me from actually using it straight away:
            http://forum.asgvis.com/index.php?topic=7646.0
            • #66
              ehi guys, do you use LAST batch render software without any problems?? mine can't save views (randomly) it says that some views are completed when they've never started...is there a solution? is it windows 7 issue?
              • #67
                I had this problem as well. Log says everything is fine but the saves weren't there. I tried custom folder instead of the default and chose C:\ and it worked. Maybe it's something with spaces in the path that messes it up, I don't know. Works like this anyway
                • #68
                  It's definitely spaces in the path of the folder, were the files are being saved. It's weird but when I deleted the spaces, my files have been saved without problems when I had a problem that you are writing about.
                  makebelievegraphics.com
                  • #69
                    in order to make batch render working fine, witch is right tool to use with Rhino4 and Windows 7 64bit?
                    i mean, last GUI version or command version?
                    • #70
                      I'm running http://software.asgvis.com/index.php...emid=439&uid=0 on my Win7x64 machine just fine if there are no spaces in the save path as described above.
                      • #71
                        hello everyone,
                        I keep getting an error
                        Microsoft VBScript runtime error
                        Permission denied
                        line: 60
                        char: 2
                        (I dowloaded it from http://software.asgvis.com/index.php...mid=18&gid=529)
                        I have Batch Render enabled in render settings. Can you please tell me what's wrong?
                        I am using Rhino 4.0 SR8
                        • #72
                          what is the difference between the list queue in the Micha render tools and the batch render?
                          why the commands of the Batchrender plugin are not working except for the Batchrender?
                          www.leobonilla.com
                          • #73
                            How can I avoid time stamp from appearing each time rendered is saved?
                            www.leobonilla.com
                            • #74
                              Hi VfR Users and MODs
                              am i understanding it right, that we only can use the Batchrenderer with the VfR Version 1?
                              If this is right, why do we not get a solution? Is this a MCNEEL thing?
                              thx
                              sanny
                              • #75
                                I use 01.05.29 VfR.
                                Is it now possible to use Batchrender?
                                thx
                                sanny
