single surface glass
  • single surface glass
    what are the settings for creating single surface glass with out weird distorting IOR?
    Re: single surface glass
    Look at the making material tutorial, there is a special glass - reflection layer + diffuse layer (color black and opacity at a color you like).
      couldn't find it... can you just tell me?
        It actually doesn't look like its in that tutorial. Basically, just have a reflection layer with a pretty strong reflection (either by a higher IOR, manipulating the colors within the fresnel map, or just using a solid reflection color) and have a diffuse layer with some blue and some transparency. Leave out the refraction layer. That should get you going. There's probably a material for this in the material downloads section, and we may even ship one with vfr, so check those too if you like.
          found the tutorials... new site is a bit hard to navigate.
            Found it in the tutorial... its at the bottom of page1.
            Weird workaround, but it works. Thanks.
              Right, I needed some time to found it.
              Damien, best you set diffuse color black. If you set a color than it will act like dust at the glass. Only the transparency color is needed to give a "glass refraction like" tint.
