Instancing a Light
  • Instancing a Light
    Hey how can you instance a light in 3.6 so you can control several lights as one? Did not see it in the updated documents.
    Let there B3D
    Steven Houtzager
    Intuitionusa.com
    3D Renderings & Animations for Product Development and Retail Design - Atlanta, GA
    Hello, Steven,
    You can select a light and use commands such as Array, or simply hold Alt and drag the light to make another instance out of it.
    It is demonstrated in our V-Ray 3.6 for Rhino feature video at around 1m25s - https://www.youtube.com/watch?v=oAYeZEDrOTk&t=1
    Once selected, the Properties' Light tab in Rhino contains 2 new buttons - "Select Instances" and "Make Unique". The Light properties are now also synched with the Asset Editor's Light list.
    Mesh Lights can be instanced by placing them in a block and instancing it instead.
    Kind regards,
    Peter
    Peter Chaushev
    Let's keep in touch
      In a related question, can we still adjust many lights simultaneously if we have placed them in a rhino group? (3.4 functionality) or we have to always make instances now? Thanks.
        Wow that instancing works well. I can also break a light free of a group.
        Let there B3D
        Steven Houtzager
        Intuitionusa.com
          Hi michail_ch,
          The 3.4 (group) behavior is controlled by Rhino and will still work.
          You don't even have to group lights.
          You can just select multiple objects/lights in Rhino and change a property.
          If the property is shared Rhino will apply the change to all objects in the selection that have it.
          In any case, I would recommend instancing the lights that you'll always want to tweak together.
          It's just a very clean solution.
          Regards,
          Konstantin
            Yes, you can click on the Make Unique button in the light properties panel which breaks the instance connection.
            If you want to copy a light without making it an instance in the first place you can use:
            Ctrl+C > Ctrl+V (the Copy to Clipboard function)
            Regards,
            Konnstantin
