Hey how can you instance a light in 3.6 so you can control several lights as one? Did not see it in the updated documents.
Instancing a Light
Instancing a Light
Let there B3D
Steven Houtzager
Intuitionusa.com
3D Renderings & Animations for Product Development and Retail Design - Atlanta, GATags: None
Hello, Steven,
You can select a light and use commands such as Array, or simply hold Alt and drag the light to make another instance out of it.
It is demonstrated in our V-Ray 3.6 for Rhino feature video at around 1m25s - https://www.youtube.com/watch?v=oAYeZEDrOTk&t=1
Once selected, the Properties' Light tab in Rhino contains 2 new buttons - "Select Instances" and "Make Unique". The Light properties are now also synched with the Asset Editor's Light list.
Mesh Lights can be instanced by placing them in a block and instancing it instead.
Kind regards,
PeterPeter Chaushev
V-Ray for SketchUp | V-Ray for Rhino | Product Specialist
www.chaos.com
Wow that instancing works well. I can also break a light free of a group.Let there B3D
Steven Houtzager
Intuitionusa.com
Originally posted by michail_ch View PostIn a related question, can we still adjust many lights simultaneously if we have placed them in a rhino group? (3.4 functionality) or we have to always make instances now? Thanks.
The 3.4 (group) behavior is controlled by Rhino and will still work.
You don't even have to group lights.
You can just select multiple objects/lights in Rhino and change a property.
If the property is shared Rhino will apply the change to all objects in the selection that have it.
In any case, I would recommend instancing the lights that you'll always want to tweak together.
It's just a very clean solution.
Regards,
Konstantin
Originally posted by SHoutzager View PostWow that instancing works well. I can also break a light free of a group.
If you want to copy a light without making it an instance in the first place you can use:
Ctrl+C > Ctrl+V (the Copy to Clipboard function)
Regards,
Konnstantin
