Rendering with GPU Issue
  • Rendering with GPU Issue
    Can you maybe elaborate on what this message means? I am testing rendering with GPU on a fairly simple scene but I get this message. To be honest, I have never really had much success rendering on GPU with VRay. My cards are a GTX 1080 and a GTX 750 Ti
Name:	GPU Issue.JPG
    Matthew Valero, ASAI
    Hello, Matthew,
    There are a number of specific conditions that may at may produce these errors. Some of them were fixed in the last two updates of V-Ray 5.
    Can you please state the versions of V-Ray for SketchUp and your GPU drivers?
    Does this error occur only with a certain scene? If it does, please share it with us via https://www.chaosgroup.com/help/contact/support/scene for further investigation.
    Kind regards,
    Peter
    Peter Chaushev
    Let's keep in touch
      VRay for SketchUp 5.10.01 (185246 2634cc52
      NVIDIA Drivers - 27.21.14.6172
      File - https://www.dropbox.com/s/qt5zde33as...UTest.zip?dl=0
        Thank you for providing the scene.
        I was not able to reproduce the errors using similar hardware to yours and the same drivers.
        Could you please confirm my suspicions by:
        1) removing the beta Cosmos assets you've used and then attempt to render it
        2) removing the Laubwerk assets you've used and then attempt to render it
        Peter Chaushev
        Let's keep in touch
          I removed the tree, which is from Globe Plants and the 2 Cosmos files. This is what happened (see below)
          (crazy thing is that when I opened this file, it said it was already open, so something was still holding on to it even though I closed it 2 days ago)
          I could not stop the render. Had to close SketchUp. Looked at my processes and low and behold I have 2 ghost sessions running from the 2 tests I did.
            ​Seems to render fine when I remove the 750Ti - Do you think it's just a memory thing, since the 750 only has 2GB?
              Hi ValeroStudio,
              It is most probably a memory thing.
              You have to keep in mind that V-Ray will be limited by the memory of the least capable GPU when you're on a multi-GPU system.
              You can also try rendering with the experimental Out-of Core mode introduced recently:
              Advanced Render Settings / render Parameters / GPU Memory management / Out of Core
              Note that this option can significantly decrease performance in specific situations (with many displaced surfaces for example).
              Regards,
              Konstantin
                Originally posted by konstantin_chaos View Post
                Hi ValeroStudio,
                Regards,
                Konstantin
                Thanks Konstantin. This worked with a file I was working on this week that crashed SketchUp when trying to render using GPU. It still seems to cause an issue with the test scene I sent you. That scene will not render at all using GPU.
                  I was able to successfully render the scene:
                  On the other hand there are some missing textures in the archive that might be preventing some of the effect to get rendered:
                  Code:
                  Bitmap file "C:\Users\xpuma\OneDrive\Desktop\rocks_ground_06_4k_jpg\rocks_ground_06_disp_4k.jpg" failed to load: error in file format:3: The system cannot find the path specified. [TABLE="cellpadding: 0, cellspacing: 0"]
                  [TR]
                  [TD]Bitmap file "C:\Users\xpuma\OneDrive\Desktop\rocks_ground_06_4 k_jpg\rocks_ground_06_nor_4k.jpg" failed to load: error in file format:3: The system cannot find the path specified.[/TD]
                   		[/TR]
                  [TR]
                  [TD]Failed to load bitmap "C:\Users\xpuma\OneDrive\Desktop\rocks_ground_06_4 k_jpg\rocks_ground_06_nor_4k.jpg"[/TD]
                   		[/TR]
                  [TR]
                  [TD]Bitmap file "C:\Users\xpuma\OneDrive\Desktop\rocks_ground_06_4 k_jpg\rocks_ground_06_rough_4k.jpg" failed to load: error in file format:3: The system cannot find the path specified.[/TD]
                   		[/TR]
                  [TR]
                  [TD]Failed to load bitmap "C:\Users\xpuma\OneDrive\Desktop\rocks_ground_06_4 k_jpg\rocks_ground_06_rough_4k.jpg"[/TD]
                   		[/TR]
                  [TR]
                  [TD]Failed to load bitmap "C:\Users\xpuma\OneDrive\Desktop\rocks_ground_06_4 k_jpg\rocks_ground_06_disp_4k.jpg"[/TD]
                   		[/TR]
                  [/TABLE]
                  I also noticed the following:
                  Code:
                  Peak memory for frame 0: 3.09 GiB collected for 22 categories
                  This might explain why removing the 2GB GPU from rendering has helped you.
                  Do you mean that 'Out of core' still doesn't solve this for you?
                  Konstantin
