Call for more testers: The mighty bug hunt!
  • #46
    Re: Call for more testers: The mighty bug hunt!
    Hi peeps! I'm new to this forum, so please let me introduce myself.
    I'm a student in Architecture and use Sketchup for 4 years on OSX now. I've used Kerkythea and Artlantis before, but when upgrading to Sketchup 7 I found out an integrated render solution was available. I knew V-Ray and the great results from the other 3d modeling programs, so I am very hopeful creating some nice scenes with V-Ray for Sketchup myself one day ;D
    You won't be surprised I walked into some bugs : after installing the program, ending up here.
    I'd like to test your beta V-Ray for Sketchup 7.1.6859 for OSX SnowLeopard.
    gr.baco
    • #47
      claali - I believe that the current beta version should be able to resolve your issue, but then again, that's why we're still testing it! We look forward to hearing your feedback.
      OutOfMyDepth - We have been trying to fix as many old scene loading issues as we can. Your feedback should be very helpful.
      baco - There have been a number of users with a similar issue, I'm hoping to hear some good news after you test out the latest beta.
      All of you have been granted access to the beta forum, please download the latest version that is posted, and post any feedback you may have. As a reminder, all comments about the current beta should remain in the beta forum.
      Devin Kendig
      Developer
      Chaos Group
      • #48
        I can't find the beta forum, I found a link but it didn't work. Does it take a while before activation?
        Thanks.
        • #49
          hmm, try again. It appears the setting didn't apply when I changed it earlier.
          Devin Kendig
          Developer
          Chaos Group
          • #50
            hello.
            I would like to download the new beta versions of v-ray
            Im use windows xpsp3 in Spanish y sketchup 7.1.6860 in Spanish.
            where I can download v-ray '?
            • #51
              hello.
              I would also like to help out on the beta testing. I have at the moment SketchUp 7 and the latest demo version of V-ray.
              • #52
                Hi guys..we are all having the same issue here..whew!!! after so many attempts and errors and I almost giving up.. i guess my solution is simple and just need some patience. I tried trice this method.... and viola it works!!!!!
                Hope it will work with you guys. Just open your skp file, then copy the entire image hold the "ctrl" key from top left edge of your screen to the bottom right, then open up a new SKP window, then paste it.... it will take a few minutes to paste the entire image.,,
                Then..render it again....hope you guys will smile again.....
                • #53
                  Hey guys, I've been accepted for the beta testing *he says excitedly!*
                  but I can't find where I need to go to download it!
                  I've found this forum which I took to be the beta forum though I may be wrong:
                  ASGVIS User Forums « Forum « V-Ray for SketchUp « VfSU BetaTesting
                  Where can I download the beta from, I can't see any links?!
                  Any help will be appreciated! I've a feeling it'll be screamingly obvious when I know so I'll apologise now if I'm just being a little slow.......
                  • #54
                    Ok ignore my last post. I've found the links :-[
                    Should anyone else struggle just look in the thread entitled "WIP testing".
                    • #55
                      ELCORTO and OSN581 - you have both been accepted in to the testing group, welcome aboard.
                      Devin Kendig
                      Developer
                      Chaos Group
                      • #56
                        mikaniko - this thread is where you sign up to become a beta tester. Your posting suggests that you are not interested in using the latest beta version, and are content with the current version you are using, is this correct? By the way, the copy and paste between windows trick doesn't fix all issues in all versions, in case anyone tries it out and it doesn't work for them.
                        Devin Kendig
                        Developer
                        Chaos Group
                        • #57
                          Now im using SU7 and vfsu 1.05 as a primary setup. Can i install SU6 with the new vfsu , for tesing alongside, my primary setup? ???
                          • #58
                            I believe you should be able to have things set up as you described Chandan. You're in the testing group now, so let us know how that turns out!
                            Devin Kendig
                            Developer
                            Chaos Group
                            • #59
                              Hi.
                              I would like to download the new beta version of v-ray for testing.
                              I'm using windows server 2008 SP2 and sketchup 7.1.6860 Pro trial in Portuguese Brazilian.
                              • #60
                                Pbarca - let us know how the latest beta works on your machine, you're in
                                Devin Kendig
                                Developer
                                Chaos Group
