I was looking to use dirt as an opacity map for a layered material but I can't seem to get the black to be black, it looks more like 50% gray. Anyone know why this is?
Dirt
You can strengthen a Curvature or Dirt map by slotting it in a Simple Mix texture and using a value higher than 1 for Multiply Result and then using the result as a blend map in Blend Material.
Peter Chaushev
Let's keep in touch
Originally posted by ValeroStudio View PostHere is the vrmat file... Mr. Gehry
I'm having an issue loading your vrmat file into V-Ray, and I'm not really sure what's causing it. I don't think it has anything to do with your file. If possible, could you attach screenshots of the material settings?
I appreciate you going through this trouble for me!
FG
2 stacked BRDF metals - the bottom is the gray color and the top is the shiny silver metal
The Opacity on the top layer is set to Simple Mix with the multiply set to 5
In the color / Texture map is a Dirt tex
The Occluded color on the Dirt settings is a Cellular procedural to give some varying worn texture.
4 PhotosMatthew Valero, ASAI
Originally posted by ValeroStudio View Post2 stacked BRDF metals - the bottom is the gray color and the top is the shiny silver metal
