if someone tell me how can i use sun into my model that would be so nice.I dont know how to put sun into my models.I searched but didnt find anything like that.I totaly dont know how to do that help please???
how to use sun?
Re: how to use sun?
I'm finding that the sun is not passing through transparent layers properly. In Sketch-Up before I render I can clearly see the sun passing through the windows into the building, but when I render the image this dose not occur and it is very dark inside. Why is this??
Re: how to use sun?
same thing happens to me, i have my difult lights checkt, i use vray glass material,i have my phisical camera on, but the sun light dosnt come in... the scene is not dark because i put my rectangular lights very very up high in the multyplier..... but the sun still dosnt come intrough the window.... how cant a ichive this? putting the sun multiplyer up very very high? or the enviorment multiplyer??
Re: how to use sun?
try to adjust the sketchup sun so you can see the actual sun facing the window directly, probably it won't show up in your sketchup model unless you have the transparency material assing to your window, but this will help you pointing the sun in the right direction.
after that check your sun by default in enviroment settings.Juan Carlos
Re: how to use sun?
Originally posted by chillinDo i have to put the window glass with imassive material for it to light up? or do i put a rectengular light outside my window?
regards,
vd
Re: how to use sun?
Here is how I do to make this scene :
Use a SU glass material for glasses of windows (for viewing shadow in scence before rendering)
Apply Clear-Glass(vismat,you can find it in C:/Program Files/Asgvis/Materials/Glass) to these Glasses
Setting scene shadow until U satisfy
Update scene,go to Vray Options,open Environtment and use Vraysky in both GI and Background
Render it and you will get the result like that,if U want a soft anf smooth shadow,U can increase the Size Multiplier of Sun
Enjoy your Product
