creating a desk lamp
  • #31
    Re: creating a desk lamp
    You may find this tutorial interesting and useful. Its for 3dsMax, but lots of useful tips for interiors.
    http://www.freeitsolutions.com/3ds/v...ial.aspx?id=22
    David
    Sketchup 2015
    Vray version 2.00
    www.davidcauldwell.co.uk
    • #32
      FANTASTIC web site, thank you very much David
      Regards
      • #33
        hi again,
        as your comments friends, I encreased the scale of rectangula light, encreased its multiplaier to 5000, and also increased hsph subdivie to 80 and checked sun in SU.the result is really bette now, thank you. but
        1)as you see the sun beams disapeared I guess it is because rectangular light isn't it?
        2)I deleted walls and draw it again in SU, I imported the 3d file from Auto cad, is it possible that darkness of scene in previous rendering was also related to walls?
        thank you very much
        • #34
          Right! I hadn't realised that you had placed the rect light in the window and I see now why it is stopping the sun getting in. You should check the 'invisible' box in the light editor.
          We all have different ways of achieving the effect we want, so this is just the way I would do it (not necessarily the best or 'right' way to do it - but here goes)
          As I said earlier - think photography!
          If a photographer had a lighting situation where there was tons of bright light coming in through a window, they would reduce the camera exposure (you've done this) and then provide some fill-in light to reduce the contrast between the very bright light coming in from the window and the areas of the room in shadow and may be too dark. So, the rectangular light needs to be big, not very bright, and positioned in the room to gently light the dark areas - its just a fill-in light.
          But first just try making it 'invisible' and see how that works.
          Good Luck
          David
          Sketchup 2015
          Vray version 2.00
          • #35
            David, let me congratulate you for your patience and for your beautiful character !
            • #36
              Well, you know we've all been there! and its nice to see someone trying!
              Sketchup 2015
              Vray version 2.00
              • #37
                that's right.
                I really think David is my teacher. and I hope he made a lot of progress in all of his living, while he is a kind man, he help the others while the others like me can not help him in case of Vray.
                I also must say thank you and congratulation for your kindness, your blessed with this moral sense. I wish I were you in this case
                • #38
                  and one more thing David
                  I am a research student, because of this I only can play with Vray about 1 hour a day. your replies encouraged me to continue learning Vray. thank you very much again for your kindness.
                  • #39
                    hi,it is my final render,although it is not still so realistic but I think as the first experiment it is not so bad,thank you every body :P ;D
                    • #40
                      • #41
                        Much better. Although there are few burned places in the scene, so you might want to decrease a bit the intesity of the light.
                        Congrats
                        www.Top3Dstudio.com
                        SU 8
                        VfS 1.48.89
                        Win 7 64-bit
                        • #42
                          Congratulations Fatemeh, I hope you will posting again soon! Keep up the good work!
                          • #43
                            thank you stefanq, it is so nice of you, yes I have started a new experiment in rendering ;D
                            • #44
                              yes 40th i have to struggle more with lighting
                              • #45
                                fatemeh
                                Final results looking much better. Maybe increase the camera speed even more and reduce the rectangular light output (I would start with 0 and increase until it gave the right effect) - At the moment there are no dark areas at all, and I feel there should be.
                                Look forward to the next one!
                                David
                                Sketchup 2015
                                Vray version 2.00
