MADO setting
  • MADO setting
    can anyone tell me, when i use Mado setting to render, why it can produce shadow in the output, i found no shadow altough default light is turn on ???? ???
    Re: MADO setting
    I'm not familiar with those settings, but the missing shadows can be caused by many things.
    What kind of lightning are you using?
    Did you used Physical Camera?
    www.Top3Dstudio.com
    SU 8
    VfS 1.48.89
    Win 7 64-bit
      Re: MADO setting
      Also, it could be the time of day which your scene is set to. I've seen a few people ask similar question where it turned out the sun was located at around noon and the shadows where nearly invisible due to that.
        Re: MADO setting
        Definitely, there are lot's of reasons that can cause shadows invisible. And by the question asked here there's just not enough info to figure out what's the issue.
        www.Top3Dstudio.com
        SU 8
        VfS 1.48.89
        Win 7 64-bit
          Re: MADO setting
          i used phisycal camera, usually when i set up my own setting (with no physical camera, default light on)it can produce the shadow, but when i used the MADO setting (which i download from download section) i can't see the shadow
            Re: MADO setting
            What kind of lightning are you using? GI or Rec light ?
            If you want, you can send me the .skp file and ill check it. (If you using VfSU v1.00)
            www.Top3Dstudio.com
            SU 8
            VfS 1.48.89
            Win 7 64-bit
              Re: MADO setting
              very kind 40th, but i dont know how to post my skp file  ???, sorry i'm new in this forum ;D, i use only the GI without any rec light or omni light.
                Re: MADO setting
                Send it by eMail AtTop@Live.com
                Or if it's larger than 10mb you can upload the file at www.rapidshare.com
                www.Top3Dstudio.com
                SU 8
                VfS 1.48.89
                Win 7 64-bit
                  Re: MADO setting
                  very kind 40th, thanks for your help, here is my skp file.
                  http://rapidshare.com/files/20548327..._EKA2.skp.html
                    Re: MADO setting
                    No problem.
                    I rendered the scene without changing any settings.
                    the shadows appear just fine.
                    www.Top3Dstudio.com
                    SU 8
                    VfS 1.48.89
                    Win 7 64-bit
                      Re: MADO setting
                      very kind 40th, ya i've tried to, but how can i change the shadow setting(time setting) because i set up the shadow from sketchup shadow setting but the shadow didn't change according my time set up.
                        Re: MADO setting
                        It's a known issue in the original release of vfsu. Every time you change SU's sun location you need manually update Vray's sun. Just go to Environment>GI>Sun>press the 'default' button and reapply the default setting (witch are Su's sun Location).
                        www.Top3Dstudio.com
                        SU 8
                        VfS 1.48.89
                        Win 7 64-bit
                          Re: MADO setting
                          thanks so much,very kind of you 40th, so helpful. now i think i should improve my skill on texture to make it more realistic. thanks... ;D ;D ;D
                            Re: MADO setting
                            No problem
                            www.Top3Dstudio.com
                            SU 8
                            VfS 1.48.89
                            Win 7 64-bit
                            • #15
                              Re: MADO setting
                              I still get this issue in the version I am using, v1.5
