Vray 1.47.01 is better with sketchup 7 or 8 or same
  • Vray 1.47.01 is better with sketchup 7 or 8 or same
    My question is in title...
    What do you think this?
    notice to users confirmed!
    thanks
    V-Ray for SketchUp 3.4
    Windows 10 pro 64-bit.
    french
    SketchUp 17 french, artisan,fredo scale....
    intel i7 4790k
    geforce GTX 980
    Ram:32 g
    if you mean 1.49.01 - SU8 has better memory management, so can handle larger files better.
      Yes 1.49.01.
      Thanks
      french
      intel i7 4790k
      geforce GTX 980
      Ram:32 g
        SktchUp 8 M2 or higher can address up to 4GB, as oppose to 2GB for the older version if you have a 64bit Windows version.
          +1 - have to use 8 M2
          Matthew Valero, ASAI
            At the risk of sounding like an idiot, what does the "M2" mean?
            I am currently using V-Ray 1.49.01.
            SketchUp 8.0.11752
            Windows 7 Professional-64 bit
            Intel(R) Core(TM) i5 K655 @ 3.20GHz
            8.00GB of RAM, 1.2TB Hard Drive
            Marcus McLin, Intern - Serena Sturm Architects
              Maintenance 2. But we are now on M5
              http://support.google.com/sketchup/b...lease_notes.cs
                M2 allowed SU to use up to 4GB of RAM. Not quite 64 bit but it sure helps.
                  M for "Maintenance" release. oops Valerostudio already got the answer...
                    Thanks for the clarification, everybody!
                    SketchUp 8.0.11752
                      Ok, thanks.
                      I want to buy a new computer and i use sketchup 8 m2 and Vray 1.49.01, My current configuration is too low to make large scenes, my pc stops rendering when I put too high resolution.
                      I work in the interior design of the restaurant and I have very big model with lots of chairs and tables, V ray don't like.
                      Sketchup files are occasionally 50 MB or more.
                      I think PCU is very important for rendering speed but i want to know if it's necessary to have much RAM (for example 32 G or 16?), because sketchup use 4 g of ram.
                      I would like your opinion as a user of sketchup + vray and photopshop, what's your configuration?
                      Is this the same problem with 3ds Max and Vray or Max manages large files better?
                      Thanks
                      french
                      intel i7 4790k
                      geforce GTX 980
                      Ram:32 g
                        I have the SU8 Pro Vray 1.49.01 on a i7 6 core (12 threads) machine with 12gb of ram and have no issues rendering interior scenes larger then 80MB.
                        The i7s are the way to go. Unless you are using crazy displacement, there should be no need for more memory than 4GB for now. I have never had memory issues in the several years I have used VR4SU.
                        Just stay clear of displacement and ALWAYS render your final hi-res direct to EXR. This saves a ton of memory and will allow you render higher res images. You just need ProEXR for Photoshop ($99) in order to open multichannel EXR files.
                          Thanks Matthew,
                          i made a rendering last night ,in PNG,and it crashed.(see attached filed).
                          yet i have 8 g ram and my model do 24 mb, why my computer stopped rendering?
                          Tonight, i will test a render in EXR.
                          french
                          intel i7 4790k
                          geforce GTX 980
                          Ram:32 g
                            A 24 MB file like that should be fine with 1.49.01 SU M5 and rendering direct to EXR.
                            • #15
                              I make a test with exr and Vray stops.I think my pc is tired!!!
                              Thanks Matthew
                              french
                              intel i7 4790k
                              geforce GTX 980
                              Ram:32 g
