Use Vray scene data on material?
  • Use Vray scene data on material?
    Say I want to import a blend shader with crazy logic from... Maya via vrscene... is there a way to enable imported shader to use scene data?
    If so, is there a way to assign a "proxy" shader to help visualise it in UE & use complex for render in vray?
    Regards
    Dariusz
    Hi Dariusz,
    Yes, you can set the imported material to use the vrscene data at render time. You can do that by enabling "Render material from vrscene" on the imported materials:https://docs.chaos.com/display/VRAYU...+from+.vrscene
    You can modify the material in the content browser however you like but when rendering, the material from the vrscene description will be used.
    Alexander
    Alexander Atanasov
    V-Ray for Unreal & Chaos Vantage QA
    Chaos
      Awesome thanks!
      Heh, I looked everywhere for a checkbox... never accured to me it might be a context menu... cool !
      Ok 1 more question, can I somehow link attributes/colors between UE shader and vrscene material ?
      I take I would need some kind of ${UE_MatName_attrName.etc.etc.etc} to be added to vrscene content script.
      I'm guessing I cant now, but could I in future?
      I could make proxy shader in UE to imitate Vray complex one & share some controls between each other this way...
      Thanks!
        Can you give a more detailed example of the usecase? Because V-Ray for Unreal can render UE shaders(simple and more complex). There is a render materials using external libraries: https://docs.chaos.com/display/VRAYU...rial+Libraries Can that work for your case?
        Alexander
        Alexander Atanasov
        Chaos
          Alexander
          I think this might be it! Thanks, will give it a go.
