Can Vray GPU use Turbosmooth's render time subdivision levels when rendering?
  • Can Vray GPU use Turbosmooth's render time subdivision levels when rendering?
    I noticed that Vray GPU uses only the viewport subdivision levels of the Turbosmooth modifier while with Vray CPU Vray always renders the render time subdivision levels. Can I make Vray GPU also use the render time levels? I can't afford to have the viewport subd levels enabled in the viewport since it's slowing it down.
    Aleksandar Mitov
    www.renarvisuals.com
    office@renarvisuals.com
    AMD Ryzen 9 9950X 16-core
    96GB DDR5
    You are referring to the "Render Iters", correct? They seem to work fine on a simple scene when rendered with V-Ray GPU. Is that not the case on your end?
      Yes, Render iters. Please see below:
      Aleksandar Mitov
      96GB DDR5
        Ah, it concerns IPR. IPR takes whatever is seen in the viewport when rendering with V-Ray GPU. We are aware of the issue, however, it is a delicate matter and is not trivial to resolve.
          Oh, I see. Thanks for the explanation. Is there a workaround for this? Maybe I can use a script that changes the Turbo Smooth render iterations on all objects in the scene with one click? I think there was one in the Soulburn scripts pack.
          Aleksandar Mitov
          96GB DDR5
