I noticed that Vray GPU uses only the viewport subdivision levels of the Turbosmooth modifier while with Vray CPU Vray always renders the render time subdivision levels. Can I make Vray GPU also use the render time levels? I can't afford to have the viewport subd levels enabled in the viewport since it's slowing it down.
Can Vray GPU use Turbosmooth's render time subdivision levels when rendering?
Aleksandar Mitov
www.renarvisuals.com
office@renarvisuals.com
AMD Ryzen 9 9950X 16-core
96GB DDR5
GeForce RTX 3090 24GB + GPU Driver 566.14Tags: None
Aleksandar Mitov
96GB DDR5
Oh, I see. Thanks for the explanation. Is there a workaround for this? Maybe I can use a script that changes the Turbo Smooth render iterations on all objects in the scene with one click? I think there was one in the Soulburn scripts pack.Aleksandar Mitov
96GB DDR5
