simple scene
    I lowered the noise threshold, and things sped up. Why wouldn't lower the threshold slow things down? Isn't .01 noisier than .003? .003 with be cleaner and slower, but in fact, it is faster.
    .003 and .005 for the light cache gave me a clean images seconds (.4 denoiser)
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
      One minute and clean enough for me! This is what I would expect with the 4090RTX. With my CPU, it was 8 minutes, with DR (44 cores) and 1 minute with the 4090RTX. I will work on DR and GPU, but with this test, DR didn't have enough time to kick in.
Name:	one minue.jpg
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        So what were your actual settings? None of this makes any sense.
          You should expect to see 6 buckets with the RTX 4090(and any other GPU)
          I rendered the scene on my RTX 4090, took 2m 42.5s ... and on my 3090 takes 4m 20.9s
          I also rendered on CPU 5950X 16-core, it took 11m 7.1s (here I'm using the standard V-Ray Renderer)
          I changed NOTHING in the scene, I rendered as is
Name:	Screenshot 2023-09-16 090757.png
          There is something wrong with your hardware setup, please run the Benchmark tool and report your scores here
          You can also do a clean install of driver, and you need to change the respective settings in Windows and Nvidia control panel to get the optimal performance. Please follow the steps in my post
          On another note, I can take a look at your setup(to save time and effort and to identify the issue) with remote access today or tomorrow if you have time, message me muhammed.hamed@chaos.com
          Best,
          Muhammed
          Muhammed Hamed
          V-Ray GPU product specialist
          chaos.com
            The scaling between the 3090 and 4090 is not great in this scene because of the scene setup, having no materials. This is normal and is expected to happen. You need something in the frame that pushes your 4090...Once you start adding some materials, you will see the power draw of the GPU climb to double what you have now
            On another note, there is no need for Denoiser or DR rendering for now. Run the GPU on some of your scenes to make sure your setup is working as expected first. Here is a good scene that pushes the GPU to its limits, if it doesn't render on 4m ,27s on your 4090 then something is wrong
            Best,
            Muhammed
            Muhammed Hamed
            chaos.com
            • #21
              I am going to start/complete an interior using my 4090RTX, but right away, I am not very optimistic. A simple space, with lots of windows, is taking 35 minutes. My CPU renders in 1/2 the time. Have newer processes leveled the playing field?
              The Haysboro -Future tendant space.rar
              would it be possible to have the scene in 3DS Max 2023 format ?
              Thank you.​
              Windows 10 - RTX 3090 - AMD Ryzen 9 5950X - 128 Go RAM
              Sketchup PRO 25.0.571 + V-Ray 7.00.03
              3DS Max 2024.2.7 + V-Ray 6.20.06
              3DS Max 2025.3 + V-Ray 7.00.04
              Chaos Vantage 2.7.1
              GeForce Studio Ready Driver Version 572.16​
              • #22
                6 is about right. It's been my experience that once you add a vraysun it will ask if you want a vraysky attached to it. The only time I add a dome light is when I plan to use a hdri to light the scene.
                • #23
                  i switched scene to: progressive mode, brute force and changed to nvidia AI denoiser and made sure my 2 4080s were on RTX mode not CUDA mode scene took 9m 8s. looks like it got to 3000-3500 passes before it shot up 56960. 2 rtx 4800s. i still have my old xeon e5-2620 v3 cpu @2.4ghz latest recommended drivers.
                  EDIT: i re-opened the scene and rendered wihtout changes and it rrendered in 7m 33s. huh.
                  • #24
                    Lol...the reason I like Corona better...faster render times on cpu since it's optimized for that workflow. Only using vray because of Vantage. It would take me forever to create an animation in Corona.
                    • #25
                      From what I see, V-Ray is still faster than them all.
                      https://www.youtube.com/watch?v=myg-VbapLno
                      Bobby Parker
                      phone: 2188206812
                      • Ryzen 9 5900x CPU
                      • ​Windows 11 Pro
                      • #26
                        I know, old thread. The nutcracker scene lasts 7:40 on my Gainward Phantom 4090, without overclocking or any optimizing. CPU time was 16:25 on a Ryzen 5950x. I bought the 4090 mainly for easier handling of big scenes and quicker IPR prewievs. I´m not so impressed in comparision to my former Quadro P5000.
                        Muhammed, it would be great if you can provide me with sources which show me to optimize the work with VRay.​
                        • Ryzen 9 5950x CPU at 4GHz
                        • 64gb Vengeance RGB Pro RAM
                        • ASUS TUF GAMING X570-PRO (WI-FI)
                        • Gainward Phnatom RTX 4090
                        • ​Windows 10 Pro
                        Workstation: Ryzen 9 5950x @ 4,20GHz 64 GB RAM, NVIDIA RTX 4090, Win10 Prof.<br>Rendernode: AMD Threadripper 2990wx 64 GB RAM, Nvidia Quadro P5000,Win 10 Prof. MAX 2025.2, VRay 6.2, ForestPack, RailClone, RichDirt, KStudio ProjectManager....
