V-Ray RT SP2 available
  • V-Ray RT SP2 available
    V-Ray RT SP2 is now available for download from our site at http://www.chaosgroup.com/
    This build provides compatibility with 3ds Max 2011 and 3ds Max Design 2011; the other changes are listed below:
    VRayRT/Max - 1.50.SP2 (10 May 2010)
    - 0002646: [new feature] Options to turn on/off rendering of proxy objects, X-Ref scenes and particles;
    - 0002724: [new feature] Support for stereoscopic rendering with different preview types (anaglyph, interlaced, checker, dual-window);
    - 0002132: [new feature] Adaptive sampling support with the ability to stop the RT once noise has cleared to some level;
    - 0001876: [feature request] Support for the offset parameters of the physical camera;
    - 0001987: [feature request] Support for mesh lights;
    - 0002764: [feature request] Support for VRayAmbientLight;
    - 0002358: [feature request] Support for bitmaps in the Gradient Ramp texture;
    - 0002617: [feature request] MaxScript callback when a frame is complete;
    - 0002313: [bug] Different result when there is a missing map in the enviroment slot;
    - 0002403: [bug] Errors when there is a Bitmap texture without a file name specified;
    - 0002078: [bug] horizontal shift for physical camera not working properly;
    - 0002246: [bug] Differences with the production renderer when texture filtering is "None" and "Blur" is other than 1.0;
    - 0002766: [bug] Animation of materials and textures is not updated in the ActiveShade window;
    - 0002765: [bug] Animation of physical camera properties (focus distance, focal length) is not updated in the ActiveShade window;
    Hey
    Thanx for info Vlado ! Looks great, from the other hand, is there any animation script or any info ?
      We are working on the script; I hope to post it here sometime next week.
        Wow thats amazing ! Thanxx u so muchhh !!
          Great update !!!
          rendering proxy and particles are just great and adaptive sampling is really nice too
          AMD TR 7980X, 256GB DDR5, GeForce RTX 4090 24GB, Win 10 Pro
          2D | 3D | web | video
          jiri.matys@gmail.com
          https://gumroad.com/jirimatys
          https://www.artstation.com/jiri_matys
          https://www.youtube.com/channel/UCAv...Rq9X_wxwPX-0tg
          https://www.instagram.com/jiri.matys_cgi/
          https://www.behance.net/Jiri_Matys
          https://cz.linkedin.com/in/jiří-matys-195a41a0
            I am a little confused , your home page says a new release, dated the 28th a may, but the download area has a 19 of may download, is it the same, and you didn't get to poat the update officaly or whats the story.
            The same appears on the cg architect website, why the late news if this is the case.
            Alos
            I am using a standard cam in max and the ortho does not work in RT.
            I ussually use RT to set up a sun study and use the animation script to render out each hour and it batch renders the whole thing for me not now for some reason.
            Any reason Why?
              rapid response .............
                philip,
                There is a RT page on spot3d (the documents for vray website) and under "unsupported" it lists ortho views as being unsupported. But, ortho RT is on the list of things to fix.
                Hope this helps.
                http://www.spot3d.com/vray/help/rt10...d_features.htm
                  Originally posted by philip kelly View Post
                  I am a little confused , your home page says a new release, dated the 28th a may, but the download area has a 19 of may download, is it the same, and you didn't get to poat the update officaly or whats the story. The same appears on the cg architect website, why the late news if this is the case.
                  They refer to the same build, yes.
                  Alos I am using a standard cam in max and the ortho does not work in RT. I ussually use RT to set up a sun study and use the animation script to render out each hour and it batch renders the whole thing for me not now for some reason. Any reason Why?
                  We don't support ortho views in the RT for now; but other than that, I am not sure where is the problem - this works fine for me if I animate the sun using the Daylight system in a simple test. What method are you using?
                    thank you
                    Phil
                      Thanks for vray-proxies in RT!!! so cool now!!!
                      www.vis-art.de
                      www.facebook.com/visart3d
                        if i downloaded Vray 2,0 Edu last week, does that include the sp2 or i have to get it somewhere seperate?
                          Yes, it includes all the fixes done for V-Ray RT 1.5 SP2.
