GPU distributed rendering problem
  • GPU distributed rendering problem
    Hi.
    I have problem with loading times when im using distributed rendering. Every frame loads 30 seconds before render starts. I think all assets (textures, models) should be loaded at first frame, not every frame. Is it normal or im doing something wrong? Scene is quite simple - just hipoly ground with 8k textures and some scans from quixel scattered by hand on it (instances)
    specs:
    master: 2 x geforce 1080ti
    slave: 4 x geforce rtx 2080 ti
    thanks for help!
    For now this is the expected behaviour. Asset caching between animation frames is planned for the future.
    Peter Matanov
    Chaos
      This is how things are working for at this point. Our developers have plans to improve this in the future.
      Nikolay Kusht | chaos.com
      Team Lead, 3D Support | contact us
        ok, thanks for an information. I moved to standalone license and im rendering locally - loading times are much faster.
