Clouds / Sky not renderring in GPU
  • Clouds / Sky not renderring in GPU
    Hi
    I may have a setting incorerect.
    The sky and clouds are not coming up in either CPU or GPU,
    Max 2023, Vray 6 (10.04) RTX 4090.
    I have changed nothing from previous work flow, so thought it might be a bug.
    Thank you
    phil
    Can somebody from support get back to about this please. Becoming an issue now.
      Hi, thanks for posting. Let me check and I will get back to you.
      Vladimir Krastev | chaos.com
        Clouds are working both in V-Ray CPU and V-Ray GPU on my setup, using 3ds Max 2023.3 and V-Ray 61004
        Here is the documentation about clouds - https://docs.chaos.com/display/VMAX/...VRaySun-Clouds
        Basically you just need to create a VRaySun and enable Clouds and they appear right away.
        Click image for larger version  Name:	3dsmax_2023-03-29_17-21-41.jpg Views:	0 Size:	62.2 KB ID:	1176899
          Thank you.
          I am using the day light set up as it is for archg viz, and photomontage work.
          I have to set the sun to the correct North Direction, and then the location and time, and when I set the sky it does not work all the time. Odd, i know.
          Thank you for the reply Vladimir. Have a good day.
          Phil
