Where are IPR settings? How to use IPR?
  • Where are IPR settings? How to use IPR?
    Hi all
    when launching IPR rendering reolution and rendering window is constantly changing wich is really annoying.
    Vray help talks about "IPR settings" tab in the render_setting/VRay tab but I cant see it.
    I see some VFB settings in the render window menu but I cant find any solution in it...
    Anybody helps with using the IPR properly please?
    (Max 2025 + Vray GPU 6 - 2.1)
    Hi fabrice_barbey
    Are you using 3Ds Max?
    You can find this option here,
    And the rest of the IPR settings here
    Check out my post about interactive rendering in V-Ray GPU here
    Best,
    Muhammed
    Muhammed Hamed
    V-Ray GPU product specialist
    chaos.com
      It looks like "Fit resolution to VFB" unchecked solved my problem, thanks.
