Gtx 970
  • #31
    I am on v2.5
    Can you try with the 3.1 release that's on the website?
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    • #32
      It might be a good idea to run the test with the 3.1 demo version.
      • #33
        Will it mess up my current version install?
        Bobby Parker
        phone: 2188206812
        • Ryzen 9 5900x CPU
        • ​Windows 11 Pro
        • #34
          Yes, unless you install it on a separate 3DSMax version.
          It is not possible to install multiple versions of the same plugin per single 3DSMax installation.
          • #35
            is there limitations on the demo?
            Bobby Parker
            phone: 2188206812
            • Ryzen 9 5900x CPU
            • ​Windows 11 Pro
            • #36
              Here are the limitations of the demo version:
              - produces watermarked images
              - does not support Distributed Rendering
              - resets the settings regularly
              There is also resolution limitation of Active Shade and Progressive Image Sampler.
              I think it is 320x240 for ActiveShade and 600x450 for Progressive Sampler but I am not quite sure in these numbers.
