I have some objects with Turbosmooth modifer applied on them. I've disabled the Turbosmooth iterations in the viewport and have set them to "2" so the objects are subdivided only in rendering. However, the objects render as if there is no Turbosmooth iterations applied. I tried both CUDA and CPU mode. Please check the screenshot below:
Does RT respect Turbosmooth render iterations?
Aleksandar Mitov
www.renarvisuals.com
office@renarvisuals.com
AMD Ryzen 9 9950X 16-core
96GB DDR5
GeForce RTX 5090 32GB + GPU Driver 572.83Tags: None
Sounds logical to me. Thanks.Aleksandar Mitov
96GB DDR5
Originally posted by Nicinus View PostMy guess would be that since you have RT in Activeshade it isn't seen as a render per se, it reflects your viewport, i.e. it looks just as it does on your screen. Set iterations to 2 for screen as well.If it was that easy, it would have already been done
Peter Matanov
Chaos
It does work when RT is in Production mode, just tested it. Good to know!Aleksandar Mitov
96GB DDR5
