RT CUDA renders VrayLightMtl brighter than it should
  • RT CUDA renders VrayLightMtl brighter than it should
    RT CUDA renders VrayLightMtl brighter than it should if you render with Physical Camera Exposure Control set to "active". It does this regardless of whether RT is used in Active Shade or Production Rendering mode.
    Only CUDA mode seems to be affected. RT CPU and the Advanced renderer render the VrayLightMtl intensity correctly regardless of whether Physical Camera Exposure Control is set to "active" or not. I'm using Vray 3.5 Beta 1 by the way.
    Please see below some screenshots + a simple scene for test. Just open it and hit render. After that render with Exposure Control disabled. Then do the same test with RT set to CPU mode.
    Aleksandar Mitov
    www.renarvisuals.com
    office@renarvisuals.com
    AMD Ryzen 9 9950X 16-core
    96GB DDR5
    GeForce RTX 3090 24GB + GPU Driver 566.14
    Thanks for the pointer; will check it out.
      The differences come from "Compensate camera exposure" option in the VRayLightMtl. It's not working with the Exposure control in the env. settings and with the 3ds max PhysicalCamera in CUDA for now.
      Peter Matanov
      Chaos
        Good to know. Thanks!
        Aleksandar Mitov
        96GB DDR5
