RT CUDA seems to be unable to render the Tiles map if there's a texture in the texture slots of that map (in the Advanced Controls rollout). Once I remove the textures it renders fine. Is this a limitation or maybe a bug?
Tiles map doesn't render with RT CUDA if there's a texture in the Tiles map
Aleksandar Mitov
www.renarvisuals.com
office@renarvisuals.com
AMD Ryzen 9 9950X 16-core
96GB DDR5
GeForce RTX 5090 32GB + GPU Driver 572.83Tags: None
Sure, I just emailed the scene to support.Aleksandar Mitov
96GB DDR5
so I was messing with this and just discovered that real world scale seems to be the problem with the bitmap.
but i still get strange results with the tiles map even without real world scale
