Tranlucent materials
Check out my tutorials, assets, free samples and weekly newsletter:
www.AddYourLight.com
Always looking to learn, become better and serve better.
Well, may be would be better if i just share the material, it's not under license and everyone who wants can play with it https://www.dropbox.com/s/mfyepgtfh4..._cells.7z?dl=0
just few tips before start playing
1. Download the latest nigtlies for max or maya, there are some fixes for the shadows and the indirect lighting that are important for this material
2. For good visual appearance the geometry must not touch the transparent zones in the material. The volumetric shader is actually 2d, there is no ray marching and if pure transparent zone is present in the mapping, the back side will be visible and the illusion for volume will be ruined. This material has two transparent areas - a small hole in the center of the slice and the area surrending the slice. Create a hole in the geometry that is a bit wider than the real hole, in order to be able to place the UV coordinates over pure opaque points. The same is valid for the outer area as well.
3. The volumetric translucent materials keep the thickness of the scanned sample, you can see the value in the info field. You have to make the geometry model in real scale, otherwise the shading will be not correct - if you make the geometry bigger the result will have less translucency/transparency, and if you create the geometry smaller the result will be more transparent and translucent.
Last edited by Ivaylo Katev; 02-02-2019, 12:16 AM.______________________________________________
VRScans developer
Originally posted by Ivaylo Katev View Posthere is an example. the material can be non homogenous as well, but oi have no good example here, that is not under NDA.Check out my tutorials, assets, free samples and weekly newsletter:
you mean the bunny material? no, it's not under nda, it's included in the library if i'm not wrong, but can't remember the name. in general this feature is not quite popular, perhaps because the customer do not know that we have it. i'm wondering where we can find free samples to include in the library, one possibility is to use soaps, they can be easily turned into slice, and there is big variety of soaps with different transparency and translucency
VRScans developer
Soap sounds awesome!
can't find the bunny material though..I don't think it's thereCheck out my tutorials, assets, free samples and weekly newsletter:
coming back to this. could you help me find that material or upload it, please?Check out my tutorials, assets, free samples and weekly newsletter:
i found it, the red one, and another green
btw, do not use builds between sep 9 and today (oct 24) for translucent materials, they were brokenLast edited by Ivaylo Katev; 24-10-2019, 07:41 AM.______________________________________________
VRScans developer
thanks! I will check them out.
Why are they not in the library though?Check out my tutorials, assets, free samples and weekly newsletter:
It should be in there though.
who is in charge of everything?
I wrote to Gavril and to sales about vrscans and there hasn't been any reply.
Is still anybody there except for you?Check out my tutorials, assets, free samples and weekly newsletter:
