Glad you’re liking Vantage!
To separate your GPU usage, you can try the following - there is an NVIDIA environment variable called cuda_visible_devices. Setting this to 0 will use your first GPU, setting it to 1 will use your second GPU, while setting it to 0,1 would use both GPUs. To use it, you need to launch your application in a shell that has this variable set. To experiment, use the CMD window, set cuda_visible_devices=0 and then run 3dsmax.exe. Now do the same for Vantage from another CMD window, with set cuda_visible_devices=1. Both applications should now just see 1 GPU each. If it’s working well for you, you can make the variable setting part of your shortcut properties.
Just keep in mind you have to start Vantage like this before starting Live Link. Otherwise the script in 3dsmax will try to start a new instance of vantage.exe without this customization.
Processes inherit environment variables from their parent process. So Phil is suggesting you create a CMD process, set the variable there (so it applies to this process) and then start 3dsmax.exe and vantage.exe respectively from separate consoles. Each will inherit the variables of the respective console. Setting environment variables in a console is done literally with “set variable_name=value” without the quotes. You can check a variable with “set variable_name”.
I haven’t tried Phil’s method though. It uses a CUDA variable and Vantage is not a CUDA application. Maybe it works. But if it doesn’t you can instead use “vantage_console.exe -deviceList” and then “vantage_console.exe -device=index” where index is 0 or 1 or whatever the index of the GPU you want to use.
“C:\Program Files\Chaos Group\Vantage\vantage.exe”
PAUSE
It works!
I switched it to device 1 (gtx 1030) and it crashed, so I know it works since that 2gb vram won’t work I bet.
However, I used this for 3ds max:
“C:\Program Files\Autodesk\3ds Max 2021\3dsmax.exe”
PAUSE
It is not using the 1030. However, it shows that it is using the 1030 as selected in vray “render gpu devices selected” inside of 3dsmax.. Wonder what is going on there? Maybe since it is a 2gb vram gpu, the 3090 is being forced to help?
Do you think I could add anything? Or am I doing anything wrong running separate batch files?
Your batch files look fine. Again, since this is a CUDA variable, I’m not sure what it affects and what it doesn’t affect. Vantage is a DirectX application and apparently the variable still affects it. V-Ray GPU uses CUDA so it is obviously also affected. But I don’t know about 3dsmax itself… Someone more familiar with the matter should chime in.
