360 VR Camera generate white lines at the edges of the cube projection
Is there a way to avoid the white lines that one can see in VR setting (oculus or google cardboard) ?
(it is the same problem with 3dsmax, btw)
Does the problem go away if you turn OFF the Image filter in 3ds max?
It should be the image filter, turn it off and will be fine :wink:
Yes, it does solve the problem with turning off the Image filter.
Thanks !
