3d tree
Does anybody have a clue as to why this 3d tree is rendering like this? It’s a skp model that I downloaded from FormFonts…Do I need to make some adjustments for it to render well?
Appreciate the help thanks
Re: 3d tree
Another 3d tree that renders like this…
Does anybody know what causes this?
Re: 3d tree
Clip mapping, transparency mapping, alpha mapping… much has been said about it on the forum, so I suggest I search. I’ll clarify from there if you need it.
Re: 3d tree
I did have a look in the forum. Basically I need to learn how to do an alpha image in Photoshop and use the original JPG with the modified “transparent” image in Vray right? Something like this? I will have another look …
Re: 3d tree
Kinda, but not really that complicated…export the image file from the SU material and open that in photoshop. It should be a png, so you should see the checker background. Make an alpha map out of that where the area where the leaves are is black and the other areas are white. Save that and make sure that you have the original map as well.
Make a linked material from the leaves material. On another diffuse layer (above or below…it doesn’t matter) add the original map to the diffuse and the alpha map to the alpha part. Right before you render go back to the SU material and change it to completely transparent. Then it should work. If you want to see the trees when you get back to the viewport, just remember to adjust the transparency back to opaque.
solution
hi madmax plz give ur dowloaded 3d tree and i make it transparent and i explain to you how to do it…
chill
Re: 3d tree
@chillrender
appreciate the help really… i will try to post the .skp model here or if not can i send it to your email??? thanks again
mmmm it’s impossible to ipload the skp model…only 128kb max file size? even the zip file is bigger than this
i’ll see how to send it to you
Re: 3d tree
okay
Re: 3d tree
hi dalomar,
How can i make an alpha map in ps and were in the linked material slot should i put it.
Cant figure out this one yet. thnx 4 d help. Still new to both Vrfsu and ps. :wink:
figure it out already max? :slight_smile:
Re: 3d tree
hi i have the solution.
1. U choose one of the plane, right click choose vraylink material.
2. U must make the other same image like in Diffuse map choose “m” in transparency ,choose bitmap. but the image should ( the leaf is black colour and the background is white colour)
3. Just render …
Hope its work…i already try..
Regards,
Nick
Re: 3d tree
thanks nick, figured it out already.
hope i can contribute useful answers also in this forum in the future.
Re: 3d tree
hey,
i have downloaded a tree from 3D warehouse, how can I export the leaf texture to photoshop to make the alphamap?
thx in advance
Re: 3d tree
RightClick on the material and there should be the option to export the texture image (material must be In Model). After that you can bring it into photoshop, fill in the background with white, and fill the original image in with black. Save as a copy.
