Hi, when trying add any V-Ray light to scene max is crashing.
dumpdata.zip (969 KB)
I have the same problem with the latest Vray 5. The first Vray5 version works fine. So that is a temporary fix.
The latest Update 2 Hotfix 2 should have a hotfix for this. Are you using it or an older version ?
Yavor
Hello Yavor,
Thanks for the answer. Nope, waiting for the update.
I tried the updated version but unfortunately it didn’t work. As Sidow said, it works flawlessly with the first version.
Can you attach a crash dump with the updated version ?
Sorry for late. Here is updated version of V-Ray crash dump files.
I just updated from vray 3.06.03 to vray 5 update 2.2 and had the EXACT same issue as @deyan_asenov . Tried to create a vray plane light / vray dome light and 3ds max 2016 instantly crashed.
Which version did you say it was stable deyan?
Tks in advance
4.30.02 is stable right now. By the way, Vantage Live Link does not work with this version.
Thank you @deyan_asenov for the reply. I’ve managed to install the 5.1.3 version and the vray lights are working, apparently so does everything else . Did not test any other version, since the 5.1.3 worked for me and I need to render some images.
I know that the 3ds max 2016 version is not officially supported, but i’m also sure the mods wont forget about us. Hope this bug is solved in the next updates and we can install the latest versions safely. Cheers!
We’ve added another attempt to fix this issue here - Chaos.
