SP3 is online
3dsMax 2014 Design:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=22328353&linkID=10381720
3dsMax 2014:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=22328132&linkID=9241178
Regards
Alex
SP3 is online
3dsMax 2014 Design:
3dsMax 2014:
Regards
Alex
Autodesk service packs are accumalitive, correct? So, if someone doesn’t have SP1 or SP 2, they can still install SP3? Or, do SP just include all the hot fixes in between SP’s?
I think you can just install sp3 and it includes all previous updates. But AFAIK hotfixes don’t exist any more, or PU or whatever they called them. Just SPs. Unless I’m mistaken?
Anyway thanks for the headsup.
“Autodesk 3ds Max 2014 Service Pack 3 is cumulative and includes all fixes found in Service Pack 1 & 2”
Okay, thanks. I installed SP3, and all seems good.
Deployed here as well and all seems fine with the job I just resent to the farm. Frames are matching the previous frames.
Finally they have fixed the xref reload memory leak!
