installed max 2020.1 update, and i have the impression that is messes up the vrayproxy scale on older scenes when i try to reopen them…or is it juste me ?
thanks
thanks
Most likely different system units in your Max versions. Try equalizing the units and import the VRayProxy afterward.
There should be no reason for this; if you have some problematic file it would be best to send it to support@chaosgroup.com so that we can take a look.
