Hi guys this is my first time to render using Vray SUn and Physical Cam. This could be more difficult for me, i need some help for all master here, for using the Vray Sun and Physical Cam… as always no post process purely Vray..
Re: 4:55 pm ( My first Vray Sun and Physical Cam )
Chillrender
Nice modelling and I like the abandoned bike!
A couple of points:-
The sky looks like the sun is setting behind the building, but the shadows are from the front. I would try a different sky.
As it is 4:55pm(?), I would also try to colour the sun (I think you just put a colour in the sun editor), and also I would soften the shadows (change the sun size multiplier to about 3).
Nice to see the sketchup model too.
Hi David
Thanks for the tips and tricks, so heres my latest output, ill change the sky background to match the sun settings, i hope this is a little bit good than my first one,
SO as always C&C are always welcome
“The sky looks like the sun is setting behind the building, but the shadows are from the front. I would try a different sky.
As it is 4:55pm(?), I would also try to colour the sun (I think you just put a colour in the sun editor), and also I would soften the shadows (change the sun size multiplier to about 3).”
How can i change the color of the sun? Is tehre a sun editor?? Thats a real problem to me because when i set “sky” into Gi panel on eviroment there´s not an option for color…so… i always get the same white tone. Notice that i´m not talking about change the color on Gi (Skylight) since when you enter on the “M” box you cancel this setting.
chill…
Check this out
Otherwise, personally I would adjust the lighting/ sun intensity so that it is either
a) bright outside with little, if any light inside
OR
b) bright inside (and bright external lights) with very low sun lighting levels - try reducing the sun ‘intensity multiplier’ to say 0.01 - that should get you ‘dusk’!!
Sorry, maybe i´m more noob than i thought.
Those settings from spot3d.com are for Vray/Su? I don´t see the sun like those settings…and i can´t adjust the Height Z well..i can´t find Height Z. So, i´m kinda lost with those tips. I even can´t see the diferece on the sky even changing sun parameters on SketchUp (because on the panel from Vray i see no diference with diferents settings), can anyone do the samething as 3dspot on Vray for SU?
Not all vrays power (complexity?) is available to us SU users, so the reference to the 3dspot examples if for the things we can change - ozone, tubidity and intensity - its just useful to see how changing these things affects the scene.
Dear Chill..
woow, it’s really nice :), just something weird with the bicycle, maybe you need to add some darkness under it, it seems to float.. i just wondering, its there any way to create an ambient occlusion vfb in vray for sketch up?
