I have a scene that I have been working on for 2 weeks. Suddenly yesterday somthing is corrupted. File size went from 11 mb to 48 mb. Today I have been merging to file the bad object. No matter what I REMOVE from the scene - the file always stays at 48mb file size, except for 1 time it went to 98!
Any part I save out of this model - is also 48mb.
WTF!?
The only other thing I can think of - I had a norton virus block pop up yesterday for some trojan thing… I have scanned the files and folders on this drive and finds nothing. Can the virus be in my max file?
Oh - and here is another probably related issue. Running out of file space on the server - I cleaned up some directories - freeing over 1 gb of space.
I think you have a case of file bloat, in the listener window type “GC()” and enter, open and close both of the xref dialogues (object and scene) then enter “GC()” and enter again in your listener window. That should do it.
It is def. related to VRAY. I made a new scene with VRAY not loaded - and it is fine. But any scene I save with VRAY as my default renderer - it is 48 mb.
thats the amount of free ram in max after the garbage collector was run
to quote the maxscript help file:
"This function returns the number of bytes free in the MAXScript heap after collection. Note that the collector may take many seconds to run if the heap is full of many small reclaimable objects. "
btw: take notice that the gc by default deletes all undo/redo states in max - so make sure you dont need to undo anything.
cya,
Mike
ps: if anyone is having problems in max 6 with displaying lots of textures causing the ram to fill up (turning the map display off doesnt free the ram afterwards), there also is a function to clear the bitmap caches freeSceneBitmaps()
my ram usage for one scene went over 2gig, disabling map display made the usage go down to 800mb, freeSceneBitmaps() got it down to 300mb
