Who's the culprit, I delete everything and the empty scene is still 12GB! Garbage collection script do nothing to solve the problem. Could it be Vrayfur?
Hello, I was working on a scene and it seems that my scene went wrong after adding vrayfur to it.A basic scene that was less than 1Gb, climb to 12Gb (the size increase everythime I save the file after adding the fur I believed. So I first delete Vrayfur, size goes up, I delete the proxy, size goes up, I delete everything, size goes up.
I tried to merge only one object to a new scene (mesh or vraylight or even helper), the new file goes to 12GB and eat 28Gb of memories, for a single cube object with 6 faces!
I tried to copy, paste beetween 2 scenes, same problem.
I try garbage collection script,as per Autodesk advice, without sucess:
“t=trackviewnodes;n=t[#Max_MotionClip_Manager];deleteTrackViewController t n.controller
and Enter
gc()”
I look at the autobackup, but unfortunatly I notice the problem to late and the 5 backup are up to 12GB
The only way is to save as 3ds, but then I have to start over all the mapping, lighting, camera setup…
Can vrayFur be the culprit and if yes, how can I get my scene.
If you encounter the same problem, thanks to guide me.
Did you delete your animation layers? Did you try cleaning scripts like prunescene, mrclean and cleaner? Did you check your scene states?
Maybe upload your scene so we can take a look.
Thanks, I’ve been able to go back to 86Mo vs 6Gb) on an older version using the script, and rebuild all the modification again.
It is either the vrayfur or some High poly object, or the combinaison of the two that make the file increase so much.
I delete them, and now the file size is under control.
What I learned: Allways keep an eyes on the file size beetween each save.
