A little Problem with the Material Editor
Hi there guys !!
…WELL this is the point …suddenly my vray it’s having a strange behaviour with the material editor..nothing shows up in the screen…sometimes appears a sphere with a colour semejant to the bitmap previously applied ,other ones the screen just gets black..nothing in it( it’s the same issue with all material:default,linked..etc.etc) its weird cuz every bitmap applied to their different layes shows up well in their respective preview screens( reflective,bump,diffuse…etc.etc.)the problem its only in the final preview-update material screen. Any idea…
Thank you so much in advance
Cheers
Re: A little Problem with the Material Editor
Got a screenshot or two?
Also, what SketchUp version do you use, and what V-Ray version do you use?
Hi thomthom
its V-Ray 1.00.0000 and skethup Pro 6 6.0.00408…this is totally new for me…i’ve never had any problems with vray…this problem suddenly appears a few minutes ago and it seems it won’t fix…4 now :cry:
First of all I’d recommend that you upgrade your SketchUp to 6.4.112. ASGVis has also recommended that users use that version or later.
I’ve not heard of the issue you have, so if you can post a screenshot it’d help allot.
Thanks thomthom… the skethcup updating works perfect…it’s weird but…that was the answer to this issue. Thanks
Cheers
