add reflection map to double side material
hello everybody, is it possible to add a reflection map to a double side material ? How ? Thanks
There are two cases to consider here:
1. If you just want a material to reflect on the back side of faces you should just enable the Reflection option called: Back Side Reflect.
2. If you want to use Two Sided material with translucency and still make it reflective, just enable the Reflections of the Base.
Regards,
Konstantin
it was so simple … :slight_smile: Thanks Konstantin !!
