Aerial Perspective Atmospheric Effect ?
Is this nice effect available for standalone version ?
Atleast its not in effect nodes.
I’ve added the node: https://github.com/bdancer/plugins\_desc/commit/ec97b260646c24057ecc4fcfca4eb5d5adbe9787 Check if it works for you.
Quick test and works, thank you again.
Atmosphere render pass is pure black, how to get render pass of Aerial perspecttive Atmospheric effect ?
Try option “Affect Environment Rays”.
I tried it yesterday and no help.
Seems this feature is not yet available.
Just to clarify: Affect Environment Rays will not affect whether or not the aerial perspective will show up in render elements. This option will make rays that directly hit the environment be affect by the aerial effect. Example: you have a cube on the scene and nothing else - everything else shows up from the background (environment) texture. This will control whether the aerial will affect the cube only or will also affect the bg texture.
Now for the render element - it is still WIP on our end. Hopefully it will be there soon. I’ll update you when it is.
I wanted to control it color in postpro so I tested render passes. I realised that its possible to use many atmospheric effects at the same time (different heights etc) and it creates nice effects. Its also very fast effect.
And thanks for the info.
