all vray shortcuts
hi,
i’m looking for a list of all vray shortcuts, specialy the one for creating a vray camera out of a perspective view.
Select the Vraycamera and ctrl. C
Preisler
I think he means if he doesnt have one in the scene at all…That is for Cloning a camera…
what i mean is, if you are in perspective view than you can use the keystoke “ctr + c” to create a standard max camera out of the pers.view.
i know there is also a shortcut to create a vray camera in place of a standard one, if anyone knows it, would be nice to share.
cheers
I dont think there is. I thought Lele’s scriptpack had a script to assign to a shortcut if i recall right
Regards,
Thorsten
You’re right Thorsten, it does have the ability (like all macroscripts) to be assigned to a shortcut.
However, it will pop up a dialog, and at least one more mouse click will be required.
You can create a vray camera, and then hit Ctrl-C (while it is still selected) to align it to the perspective view. Is this the shortcut you’re thinking of?
@Artland/ @ErikCamper
Sorry for my bad atemp to help, it was not clear enough :slight_smile: so here goes:
- In any scene, ctrl + c creates a new standard Max camera and yes you can copy any camera with ctrl + c and then ctrl + v.
But there is also a Vray trick to the command. Create a Vray camera anywhere in the scene or select one already created. When still selected go to Perspective view and then hit ctrl + c and the camera will align to Perspective view.
My work around for aligning a Vray camera to a standard Max camera is: In camera view for the standard Max camera hit P for Perspective view, then select the Vray camera and hit ctrl + c and the two cameras will align.
Preisler
