Animate Container Dimensions
Is animating the container dimensions (Grid cell dimensions) supported?
It appears to break the Increase and Decrease resolution features. When Phoenix tries to compensate for the resolution change by increasing or decreasing the grid cell count it fails if the grid sizes are already animated. Very weird stuff happens.
Hey,
Animating the grid size is not support, maybe you can use the adaptive grid settings instead? Can you give us a bit more information on how would you like to expand the grid?
Thanks for the reply, Georgi.
Ah, OK. Weird thing was that it seemed to be working until I tried to change the resolution.
I was just trying to optimize the size of the ocean mesh sim based on what was seen in camera and where objects were moving. Ended up just using a fixed size.
Sadly, I don’t think adaptive would help here, other than for Z, with which I am using it.
