Animated Camera clipping won't clip
I have a camera in a scene which moves through several views in 4 frames. On last frame it has to use clipping but it doesn’t. I went to curve editor and I can see it is set to 1 on that frame, also it’s checked under camera misc options. I also tried to make this camera clip on all frames, but as long as the “check” on/off is “animated” it doesn’t work. I tried a new camera on the same scene and it works…until I animate the check button.
Any ideas?
It doesn’t work for me too - I’ll add into our database.
Meanwhile you could avoid that by keeping clipping always on and do a stepped animation of far clipping plane.
You could enter a very high-value for all the frames which doesn’t have to be clipped and set a desired value for the ones that must be clipped and use stepped-tangents-keys.
Here is one very simple example.
1.Frame 0 - far-clipping-plane set to 99999.
2.Frame 1 - far-clipping-plane set to 1000
3.Frame 2 - far-clipping-plane set back to 99999
Yer, that was my plan. Thanks :slight_smile:
