Animated RTT/baked maps do not save
Hi there - I’m trying to bake a sequence of texture maps in the usual way that works with all other renderers. However, Corona only saves one frame (frame0000) and then overwrites it continually with each new frame it bakes. So it is impossible to bake a sequence.
I saw the earlier bug about RTT not saving at all unless you have “elements active” ticked on the render elements. That is still the case, but this is specifically about baking sequences.
Using corona 1.7, 3ds max 2017.
In the meantime I hacked this script together, which does it one frame at a time
fn BakeBeautyCorona Fnum chan obj size =
	--Clear all render elements
	obj.iNodeBakeProperties.removeAllBakeElements()
	--Preparing the Bake Elements:
	be2 = Corona_Beauty() -- instance of the bake element class
	be2.outputSzX =be2.outputSzY = size --set the size of the baked map --specifythe full file path, name and type:
	x = (Fnum as integer)/TicksPerFrame
	formatNum = formattedprint x format:"04d"
	be2.fileType = (getDir #image+"\\"+obj.name+"_beauty"+formatNum+".png")
	be2.fileName = filenameFromPath be2.fileType
	be2.enabled = true --enable baking
	--Preparing theobjectfor baking:
	obj.INodeBakeProperties.addBakeElement be2 --add second element
	obj.INodeBakeProperties.bakeEnabled = true --enabling baking
	obj.INodeBakeProperties.bakeChannel = chan --channel to bake
	obj.INodeBakeProperties.nDilations = 1 --expand the texture a bit
	select obj --we are baking the selection, so we select the object
        --Call the renderer to bake elements:
	render rendertype:#bakeSelected vfb:off progressBar:true outputSize:[size,size]
	0
)--end fn
--set your frame range here in frames
for frameNum = 0f to 10f do
	--Call the Bake function with the object and the desired size
	--format: BakeDiffuseAndLighting frameNum channelToBake objectName resolution
	BakeBeautyCorona frameNum 2 $object1 512
	BakeBeautyCorona frameNum 2 $object2etc 512
	slidertime  = frameNum
	max select none
All you need to do is use a UVW XForm modifier, then animate the u and v coordinates using negative integers corresponding to how many UDIMs you have. Btw, this is not an issue with Corona, it’s how Max works, as there is the same behaviour when using Scanline.
I just realised that you are probably talking about rendering out the same map over time, rather than multiple UDIM tiles, right? If so, then my comment doesn’t really apply.
Thanks, yes I was talking about rendering the same map over time. Although UDIM support in corona would also be great :smiley:
The problem with my hack is that it sometimes fails randomly with this message: “error in configuration file config-‘c:\users\mike\appdata\local\autodesk\3dsmax\2017 - 64bit\ENU\plugcfg\corona\15532570.conf’ correct/delete it and restart 3ds max”
So it would be great to get this bug fixed properly.
Hello there casinowilhelm!
Did you get any solution for this problem?
I’ve been cracking my head for a few days and finally solved the mystery, but could’solve the problem itself.
I also tried to run your script with no success, but the problem in this case is probably between the computer and the chair :smiley:
I put an attachment of one of my failed attempts, if you can shed some light to help me I’d reeeeally appreciate a lot!
And let’s wait for the final and real solution with full support to animated render to texture anytime.
Well it’s 2020 and this bug is still ongoing :smiley:
Sadly it looks that idea to fully support RTT was completely abandoned by Corona team. It’s not even on roadmap anymore :[
Possibly true…
