Hello, I`m rendering a animation and the result is one frame darker than other.
Have somebody experienced this.
Thank´s.
Thank´s.
uncheck RANDOM and recycle the prepass solution
check your authorisation with Chaos.
i got the same problem even without animation.
after rendering the irradiance map, i render the same frame from
the saved map again and again…
every time it renders lighter,darker and lighter, lighter, darker, darker, …“randomize samples” is turned off, but it`s changing it`s brightness every time it`s re-rendered.
what can i do?
at the moment i am rendering only stills, so it is not such a problem,
but…
guys’ … Are you running a Legal copy of vray … if you are then you need to contact Chaos because you have an Authorization problem..
this was written into the program so every frame would be slightly different from the last … so in affect if you happened to get hold of a Bent copy of vray and try to do animations, they would Flicker…
look through the archive’s in this forum and you will see the same post appear time and time again…its nothing to do with randomize sample’s… ![]()
