Hi I have a problem rendering animations with Vray.. the problem is each frame differs in brightness than the other.. I even tryed it on a white background RGB all 255, some frames become less.. so the end result I get is a flashing animation. I also may render the same frame, change some AA settings, each time with a different brightness :?
hehehehe…this is quickly becoming the most known "issue
" about vray…I guess it’s a reflection of how many legal versus “black” versions of vray are out there and how many people are using authorized versions versus cracked…
if it wasn’t sad because of all the work vlado and the other guys put into this plugin, this whole thing would almost be funny… :x
refer to this…
http://www.chaoticdimension.com/forums/phpBB2/viewtopic.php?t=5968
paul.
