I’m following the tutorial on spot3d to do a moving camera + moving objects render on a file with frames in the negative. So frames from -200 to frames 66.
I’ve made the prepass which resulted in the files Longshotz.vrmap and 200 files with the name Longshotz-200 to Longshotz00068 but with no file extension at all. When I set the Irrmap mode to animation ( rendering) then I get this error:
// Warning: Error loading irradiance map: Error opening file //
// Error: Could not load irradiance map //
// Error: This irradiance map cannot be used in animation mode //
I have set it to open the .vrmap file. So in theory it should work.
Could the problem be that V-Ray simply is confused about the negative frame values/naming?
