I am new to this forum and just wanted to try the escape trial but:
I have just installed the Enscape trial version for Mac - Archicad.
As soon as I want to place an object from the Enscape library, I receive a bug report and Archicad closes.
I use Archicad 26.
My Computer:
MacBook Pro mit Apple M1 Max Chip, 10‑Core CPU und 32‑Core GPU - Space Grau
Does anyone have a similar problem? Thank you for your help and kind regards,
Katharina
Hey @snud_Katharina , we have just released a new version of Enscape for Mac, would you mind updating and checking if that resolves the issue?
https://enscape3d.com/download/
Hi @Kaj_Burival_1
thank you very much for your answer.
I just downloaded enscape today for the first time, so unfortunately it is the new version. It is the trial, if this makes any difference.
Is there anything else I could try?
Thanks for your help!
Thanks a lot for your reply as well.
This should not be tied to using your trial time at all, so please ideally also submit us a feedback report via the dedicated Feedback button as detailed here:
https://learn.enscape3d.com/blog/knowledgebase/using-the-feedback-button/
Afterward we’ll be able to check out your log files especially in order to troubleshoot the exact cause behind this.
I experience the same problem when I try to place objects from Asset Library. Have it also reported by feedback button in Enscape.
Using Mac mini (M1, 2020)
Wondering what the problem is.
lody88
November 3, 2023, 3:24pm
6
