ArchiCAD Material Library
Is there a Tutorial how to work best with the Enscape Material Library in ArchiCAD?
Could not find anything helpful with google.
Tutorial German would be good, but english would also be ok.
Thank you
Hi @Timmo , if you haven’t already, check out our knowledgebase article here - Using the Library should be rather straightforward. Are you perchance also looking for a tutorial about the Material Editor itself, or solely the library? Danke im Voraus!
When opening the Enscape Material Editor:
Isn´t it possible with the use of a pipette or something, to click in the Archicad-Window to select a material? Which would then selected in the Enscape Material Editor (like it is in SketchUp)?
