Urgent help needed with fog artifacts
​Hello. I need urgent help with artifacts in fog. Flickering squares appear in the render when I render with fog
Here’s a screenshot. Anybody know the cause?
I just found out that it’s not only with fog but also without
Hi, thanks for posting. Are you using V-Ray CPU or V-Ray GPU? Could you send us the scene for review? This can be done here or trough the support contact form. Please include a link to this thread in case you choose the contact form.
Are you using distributed rendering? Is this the only scene that you have with this issue? Have you tried to reset your render settings to default? Please try that and let us know how it goes.
I’m not allowed to share the scene unfortunatly. But here are some details
CPU (no problem on GPU)
I’ve reset render settings
Problem in Maya 2024.1 and 2023.3
Okay, I’m have shared the scene now through support. #168185
There is something in the scene. Without reviewing it we can not help much. Please send the scene to support. Your scene will be kept in a isolated drive, strictly confidential and used only for troubleshooting purposes. If you can not send it then open a ticket so we can possibly meet for a team viewer session and try troubleshooting directly on your computer.
I DID send it through support. I quoted the ticket number…
You had sent a message while I was writing my post, I saw it too late and this is why we got this doubling of messages.
After reviewing the scene we found out that the VRayEnvironmentFog and adaptive lights do not work together very well in this specific example. To workaround the artefacts, lights evaluation has to be switched to “full evaluation”.
The issue is reported under VMAYA-12486 in our bug tracking system.
