The assets wont display in enscape even though they are visible in rhino. They are a particular layer but when you do block edit they are in fact on another layer.
They do not display in even after I block edit and change them to the layer i actually want them to live on.
Large team which seems to be slowly finding the same error throughout the files
@kingsr , I’m sorry to hear about this problem in general.
To get behind this behavior it would be easiest if there is any chance you could send in an example project with which you experience this? Could you please also make sure that you’re using our latest release? Thanks a ton in advance for your cooperation.
If you have this version installed, please also make sure that the scaling in Rhino is set to “centimetres” - this should then resolve this behavior at hand. Let me know in case it does not please!
Hi I’m having the same issue. It is one specific enscape block that shows up in rhino but stopped showing in enscape. It was working fine last time I opened it a few hours ago.
Also, at the same time this happened some of the blocks changed scale while others remained the same. I did not change the scale of my model or the units.
Any help would be appreciated. Also, happy to share the model if it helps.
