Batch render Bug
Hi Guys,
I need to do a batch render overnight.
I have installed batch render and have added 4 files to the que with the according view.
When i hit start, it opens the first file and then immediately opens the next. i then get a pop up saying " wait for the first render to be completed. It will then render the first file as planned but in the background the next file is already opened.
It will not however render the next one unless i “ok” the the pop up from before.
As soon as i press OK, it will try and open the next file immediately and the problem repeats itslef.
Basically it looks like the batch render script is wanting to open the files before it has finished rendering…
Any ideas?
Cheers
Justin
Re: Batch render Bug
You’ll need to enable Batch Render in Global Switches for each file. That will lock out Rhino until the rendering is finished.
