Hi All,
I’m having problems with the batch render tool. I’m uploading different files saving the views and uploading them etc but when I start the batch render it starts normally images renders for 2 seconds and moves on to the next one. Furthermore It seems to overlap images as in this render… i’m rendering letters as you can see A and B are overlapping. I’ve just applied a black material to run through a few letters quickly
Would anyone have an idea as to what might be the issue?
i’m using rhino 5 and vray 2.0
thanks in advance.
Jean
Jean,
Which version of V-Ray For Rhino are you using? Are you using the latest service release? Can you post a file that is having this problem?
Thank you.
Matthew Newberg
V - Ray For Rhino Developer
Hello Matthew,
Thanks for your reply,
I believe I have the latest release as I “believe” I upgraded in October together with Vray express. The file I start from is attached. I then upload other pieces into it save them and open them in the batch render window. Really following the chaos group walk through.
Thanks for the help,
Jean
A batch.zip (2.39 MB)
Hi guys,
I really wish I could get more guidance on this issue. I have updated all and every parts yet it is not working.
I have replied with a private message. If you are unable to receive the private messages, please email matt.newberg@usa.chaosgroup.com.
Hello everyone,
I’m having the same problem. At the moment I’m using an Evaluation Version of V-ray 2.0 for Rhino. Could be this the reason why i can’t use properly the render batch tool?
