Bitmap Filter Error
So, I vented a bit about this on the CGA forums a little while ago. I think I’ll quote myself:
Here is the message I get:
Here is the thread if anyone is interested:
http://www.cgarchitect.com/vb/21473-high-res-crashes-viz.html
As I mentioned in the post, I love Vray’s capabilities as far as great materials, cameras, hdri, etc. but if you can’t render a decent resolution image, the renderer doesn’t do anything for me. So far every image I render has limited entourage, and I have to render in regions, then post stitch. Not the ideal work-flow if you ask me. 3gig switch doesn’t work for me either. How is everyone rendering stuff with 1.5 r3 and hundreds of people, plants, and cars without getting problems like mine? Is Chaos fixing anything? Or is it a Max issue (or Viz 2007 in my case)?
VRIMG = No Problems!
Maybe you should learn your tools a bit. :wink:
This particular message is displayed by 3dsmax itself, and not by V-Ray. You can work around it by using the Bitmap pager in 3dsmax.
For rendering high-resolution images, it is strongly recommended that you use the .vrimg image output as pointed out by Rerender.
Thanks guys. I have another project due tomorrow. I’ll try it out.
You guys are my new best friends!!!
At first I was getting a little frustrated, because I am no dos prompt man, but I downloaded the GUI Fidor Binka thing, and it is working like majic. My scene rendered in like 15mins and no errors. You should make this thread sticky so it is easy for people to find it.
http://www.chaosgroup.com/forum/phpBB2/viewtopic.php?t=18050&highlight=gui
Cool, glad to help. :smile:
